How to store etching solution after use?
Discussion in 'General Electronics Chat' started by Bjornk, Sep 7, 2013.
  1. Bjornk
    Jan 28, 2013
    12
    I have been making some PCBs and I wonder how to store the etching solution. The sodium persulfate I use was in powder form, before I desolved it in water and used it.
    When making the PCBs I use a pyrex measuring cup.
    Can I store the solution in a bottle with a stopper/cork? Or do I have to store it in a open jar.
    How do you store your PCB etching fluid?
    Sodium persulfate datasheet:
    https://www1.elfa.se/data1/wwwroot/assets/datasheets/110170_eng_msds.pdf
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Mixed product should be stored in a ventilated container as some oxygen gas will be released. I guess using an empty 4 liter windshield detergent bottle. Or empty hooch container depending of which part of Norway you are from:p. With the lid not fully tightened. So the gassy can escape will work OK. For disposal use one of those "gjenbruks-/miljø-stasjon" but mark the container properly. Do not just use the drain
    PackratKing likes this.
  3. nerdegutta
    Dec 15, 2009
    2,572
    807
    That is exactly how I store my Ferric Chloride.
  4. sheldons
    Oct 26, 2011
    616
    101
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Be aware fumes from many etchants will eat all metals stored around them, such as tools. I have ruined a fair share of tools finding this out (several times).
    I wrap a rolled up paper towel tightly around the cap and bottle, and tape it tightly into place. This absorbs the fumes, and give the fumes something to eat beside my tool box (or whatever).
    I put this advice in my PCB etching article, How I make PCBs
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I squeeze the bottle a bit (so it is not full volume) and screw the lid on airtight. That stops it releasing the fumes.
