how to stop a program and see what it prints
Discussion in 'Programmer's Corner' started by EngIntoHW, Oct 19, 2012.
  1. EngIntoHW
    Apr 24, 2010
    128
    I'm programming in C language.
    I use printf function and when I run the program, I cannot see what it prints.
    What would be a proper way to hold the program at a desired point?
    Edit:
    I'm using Dev-C++ Compiler
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Which C compiler are you using?
  3. EngIntoHW
    Apr 24, 2010
    128
    Dev-C++ Compiler
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Try this. I will also strongly recommend that you learn how to use the debugger. Like setting break-points, add a watch, or do some single stepping. Many beginners think this is a waste of time. But trust me then I said this is a must. Try this Google search
    Code ( (Unknown Language)):
    1. #include <stdio.h>
    2.
    3. int main()
    4. {
    5.   printf ("Press ENTER to continue.\n");
    6.   getchar (); // wait for input
    7.   return 0;
    8. }
    1.
    2. #include <stdlib.h>
    3.
    4. int main()
    5. {
    6.   system ("pause"); // execute M$-DOS' pause command
    7.   return 0;
    8. }
    9.
  5. EngIntoHW
    Apr 24, 2010
    128
    works great, Thank you!
  6. kubeek
    Sep 20, 2005
    4,687
    805
    That is not a good solution as it is dependant on some rather old code, better way is to start the command line and run the program from there instead of double clicking on it.
    Also the approach with pause won't help you when you have some console program like gcc which just blinks and dissapears, and you want to see result. Then command line is your only option as you can't change the program you are running.
  7. t06afre
    May 11, 2009
    5,939
    1,222
    Maybe, but as I understand it. The OP is running the program from the compiler enviroment just to learn C. Then this method will work more than good.
