How to stop a device when light on?
Discussion in 'Homework Help' started by navaneet31, Mar 1, 2011.
  1. navaneet31
    Mar 1, 2011
    I want to make a project.In traffic signals red ,yellow,and green colours are there.When red light start glowing the device(car or bike) automatically (switch off) i.e automatically stop.i want to make that project .can any one give me the circuit diagram...
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You seem to be wishing to make a device that can spot traffic control lights with absolute accuracy. This would seem to present quite a challenge - especially at night when there are many other light sources present that would make positive identification of traffic light difficult.
    When you say
    that sounds like the vehicle will stop without regard for the other traffic.
    Can you tell us how you are planning on dealing with these problems?
  3. navaneet31
    Mar 1, 2011
    i just want to submit as a project in my colz .Ignore disadvantages..can u help me
  4. Adjuster
    Dec 26, 2010
    2,147
    300
    This problem would require more than a "circuit diagram" for its solution. Correct recognition of visual cues by a machine in an uncontrolled environment is a subject for advanced research. Some people are sceptical about the degree to which this will ever be possible.
  5. navaneet31
    Mar 1, 2011
    else when a signal is sent it will recieve by the reciever then the motor will stops.Is it possible
  6. t06afre
    May 11, 2009
    5,939
    1,222
    It is possible to make this setup in a controlled setting. Like in your school lab. But for a real world setting. Not very likely.
    By the way what is "colz", and is this a school project
  7. navaneet31
    Mar 1, 2011
    k
    give me the circuit and necessary details..plzzzzzzzz
  8. Kermit2
    Feb 5, 2010
    3,838
    961
    give me
    give me
    give me
    gimme gimme gimme
    I don't know of anyone besides the IRS for which this approach works
  9. Georacer
    Nov 25, 2009
    5,151
    1,266
    You could use a photoresistor. With correct calibration under a controlled environment, you could distinguish red and green.
    I emphasise on controlled environment.
  10. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Can I contact your instructor? I'd like to get credit for my work.
  11. cumesoftware
    Apr 27, 2007
    1,330
    11
    Good one! Well said!
