Hello, I am going to be building a circuit that will be operating at high voltages
( about 100kv or so). The problem is I need to be able to switch it off quickly (about 1 nanosecond and under). Since the switching times are faster then any relay I know could handle, I figured I would end up using transistors controlled by a pulse generator. The problem is I can't have the transistors directly controlling the voltage as they would just short circuit. So What I thought about doing was dividing the voltage using a voltage divider down to a reasonable range of about 100 volts, then having the transistor control the low voltage but I just don't know how to step the voltage back up to 100 kv afterwards
Does anyone know how to, or maybe a better way of doing it without the voltage divider. I just need to be able to have a switching time of 1 nanosecond and under, So from off to full on in about 1 nanosecond.
