How to start an electronic project?
Discussion in 'The Projects Forum' started by onebrain2, Apr 7, 2016.
  1. onebrain2
    Apr 3, 2016
    9
    I am Angolan citizen who is working in electronic field as a electronic technician repair, there are a lot of questions in my mind, i will post one by one here so you can help me, i would like to build a dc power regulator with input of 18V and a desired output 12V to work with a power inverter of 1000W and 12V in input.
  2. blocco a spirale
    Jun 18, 2008
    1,460
    370
    You will need a DC-DC converter with a 12V output at around 100A if you want to get 1kW out of the following inverter.
    It would be no more difficult to build a 1kW inverter with an 18V input..... which is by no means easy.
  3. tcmtech
    Nov 4, 2013
    2,111
    1,751
    Where is the 18 volts coming form and what are y9ou intending to do with the power at the end?
  4. mcgyvr
    Oct 15, 2009
    4,791
    975
    please pick a different starting project.
    That is a horrible project for a beginner..
    Try something with very low voltage and low current..
    onebrain2 likes this.
  5. ScottWang
    Aug 23, 2012
    4,930
    777
    So you want to build two projects, the first one is 18V to 12V regulator, and the second one is Io=12V/1000W=83.3A inverter (eff=80%, Ii=104.2A, eff=90%, Ii=92.6A)?
    You want to build both or just the regulator?
    What is the load for inverter?
  6. onebrain2
    Apr 3, 2016
    9
    it is coming from a solar panel wich i can´t see the specification just measure the output power
  7. onebrain2
    Apr 3, 2016
    9
    i need to use the inverter to work with my domestic stuffs in my house, so total load power maybe 800W, i need first regulate the power then use it with the inverter wich i already have.
  8. onebrain2
    Apr 3, 2016
    9
    it is coming from a solar panel, wich i do not have the specification because someone erased
  9. GopherT
    Nov 23, 2012
    6,309
    4,030
    Did you measure the solar panel voltage with a load connected to it or "open voltage" - with nothing connected?
  10. tcmtech
    Nov 4, 2013
    2,111
    1,751
    Okay. First thing to do would be to dump the solar panel power into an adequately sized battery (12 volt 100+Ah deep cycle set) with some sort of charge controller being a solar panel by itself sill not support any kind of power inverter load.
    Or directly grid tie the solar panel and pirate back feed the power to your whole house thus cutting your electric bill down without the hassle of dealing with batteries, charge controllers and hooking and unhooking things from the inverter as the power is available.
    All you need to know about DIY GTI builds can be found here. http://www.electro-tech-online.com/forums/alternative-energy/
    Just some stuff to research and think about. :cool:
  11. onebrain2
    Apr 3, 2016
    9
    yes, the 18V is with open voltage, nothing connected
  12. GopherT
    Nov 23, 2012
    6,309
    4,030
    Then connect it to a load and measure the voltage. It may drop significantly (e.g. 12 V).
  13. ScottWang
    Aug 23, 2012
    4,930
    777
    Inverters should be have Vi, Ii, Wi, Vo, Io, Wo, what are yours?
  14. tcmtech
    Nov 4, 2013
    2,111
    1,751
    And how big is this solar panel?
    What's it short circuit current?
    Can it put out over 800 watts to begin with?
  15. onebrain2
    Apr 3, 2016
    9
    ok, i will check out this units then tell you
  16. onebrain2
    Apr 3, 2016
    9
    the solar panel doesn´t have a specification paper, someone removed it. but i will know how many cells it have then tell you.
  17. tcmtech
    Nov 4, 2013
    2,111
    1,751
    A rough estimate of its dimensions and wire sizes would tell us the basics.
    Unless this panel takes up half the roof of your house I doubt it will put out 800+ usable watts.
  18. #12
    Nov 30, 2010
    16,685
    7,324
    So measure its output...or are you planning on designing and building a 1000 watt inverter without owning a meter?
  19. tcmtech
    Nov 4, 2013
    2,111
    1,751
    Sure ! Why not? A little detail like that will never stand in the way of a guys dreams of energy independence you know! :oops:
