How to solve this circuit ?
Discussion in 'Homework Help' started by curry87, Jan 7, 2011.
  1. curry87
    May 30, 2010
    101
    I have a circuit with a missing voltage value at vb im trying to solve.Cant calculate the current though r1 or r2 or r3 because dont know vb.
  2. Jony130
    Feb 17, 2009
    3,991
    1,115
    Do you know superposition?
  3. curry87
    May 30, 2010
    101
    No i know KVL,KCL,ohms law and equivalent circuit thats about it.Other than superposition theorem what other ways are there to solve it please give an example of each thanks.
  4. breadboardkid
    Jan 2, 2011
    I would look up a uide for vb or you will never get to know whats wrong with your circuit :D
    -BBK
  5. Jony130
    Feb 17, 2009
    3,991
    1,115
    OK so first we start with superposition:
    So first we remove V2
    So circuit look like this:
    And we find
    Vb_1 = V1 * (8Ω||2Ω) / ( (8Ω||2Ω) + 4Ω) = 5.71428V
    Second step is to remove V1
    Vb_2 = V2 * (8Ω||4Ω) / ( (8Ω||4Ω) + 2Ω) = 18.28571V
    And finally Vb = Vb_1+Vb_2 = 23.9 ≈ 24V
      File size:
      23.6 KB
      92
      File size:
      21.4 KB
      93
      File size:
      21.6 KB
      97
    curry87 likes this.
  6. hobbyist
    Distinguished Member
    Aug 10, 2008
    773
    62
    Another way would be to find an equivalent, circuit.
    remove R3 and find the equivalent voltage, and equivalent resistance, between the two points where R3 was at.
    Then draw an equivalent circuit consisting of the equivalent voltage source (Vth), and the equivalent resistance, (Rth), in series, then in series place the R3, and solve voltage using ohms law.
    There are quite a few ways to analyse linear circuits, by learning and applying as many theorems possible, gives you a better understanding of circuit analysis.
  7. curry87
    May 30, 2010
    101
    Why is it when i apply the equation for the above circuit to this simpler circuit i get this:
    vb_1 = v1 *(16ohm+16ohm)/(16ohm+16ohm)
    vb_2 = v2 *(16ohm+16ohm)/(16ohm+16ohm)
    vb_1 = 10v *(16)/(16) = 10v
    vb_2 = 30v*(16)/(16) = 30v
    vb = vb_1 +vb_2 = 40v
    But on spice its says the node vb = 22.5v is above equation only good for resistors in parallel ?
  8. Jony130
    Feb 17, 2009
    3,991
    1,115
    Becaues you have errors in your equitations
    Do you understand why this is correct ?
    vb_1 = v1 *(6ohm)/(16ohm) = 3.75V
    vb_2 = v2 *(10ohm)/(16ohm) = 18.75V
    Vb = 22.5V
    curry87 likes this.
  9. hgmjr
    Jan 28, 2005
    9,030
    214
    Here is the Millman's Theorem expression for Vb:
    V_b\ =\ \Large \frac{\frac{V_2}{R_1}\ +\ \frac{V_1}{R_2}}{\frac{1}{R_1}\ +\ \frac{1}{R_2}\ +\ \frac{1}{R_3}}\ =\ \frac{R_2R_3V_2\ +\ R_1R_3V_1}{R_2R_3\ +\ R_1R_3\ +\ R_1R_2}
    Here is the Millman's Theorem expression for current in R3:
    \frac{V_b}{R_3}\ =\ \left( \Large \frac{R_2R_3V_2\ +\ R_1R_3V_1}{R_2R_3\ +\ R_1R_3\ +\ R_1R_2}\right)\ *\ \frac{1}{R_3}\ =\ \Large \frac{R_2V_2\ +\ R_1V_1}{R_2R_3\ +\ R_1R_3\ +\ R_1R_2}
    Here is the Millman's Theorem expression for current in R2:
    \frac{V_2\ -\ V_b}{R_1}\ =\ \left[ \Large V_2\ -\ \left( \frac{R_2R_3V_2\ +\ R_1R_3V_1}{R_2R_3\ +\ R_1R_3\ +\ R_1R_2}\right)\right] \ *\ \frac{1}{R_1}\ =\ \Large \frac{\frac{R_2R_3V_2}{R_1}\ +\ R_3V_1}{R_2R_3\ +\ R_1R_3\ +\ R_1R_2}
    I'll leave it as an exercise for anyone interested to form the expression for the current in R1.
    hgmjr
    curry87 likes this.
  10. thatoneguy
    Feb 19, 2009
    6,357
    718
    Dang, that's a Beautiful Post!
    More people need to read my sigline. ;)
  11. hgmjr
    Jan 28, 2005
    9,030
    214
    Thanks for the compliment.
    I absolutely adore Millman's Theorem and LaTex is a really handy way to express the equations. My AAC blog is focused on Millman's.
    hgmjr
  12. hobbyist
    Aug 10, 2008
    773
    62
    After reading the above post, I got my CIE books out, and found 2 pages devoted to millmans theorem.
    But it wasn't in the one book called "network theorems", but rather it was in the next book called "ADVANCED network theorems".
    After rereading that, this does make it much easier to analyse parrallel circuits as in the OP's post, which contains voltage sources.
    It is really nice how there are a lot of network theorems to choose from to do a circuit analysis. Each theorem is a special tool in itself, to help electronic engineers analyse complicated circuitry.
  13. hgmjr
    Jan 28, 2005
    9,030
    214
    The common misconception that Millman's Theorem is limited to voltage sources is why it has such a poor following. Millman's Theorem is not limited to circuits with voltage sources; it works equally well with circuits containing current sources.
    hgmjr
  14. hobbyist
    Aug 10, 2008
    773
    62
    Yep, I know, actually current sources, eleiminates one step in the process, of calculations, because you don't have to convert the E/R to a current value.
    Its already done for ya.
