How to solder a chrystal that does not sit flat(image included)
Discussion in 'General Electronics Chat' started by Mark Smith 1, Feb 19, 2016.
  1. Mark Smith 1
    Feb 19, 2016
    I have a PCB board where I place a chrystal onto it by putting the legs through the holes then bending the chrystal so it lies flat. Problem is sometimes the chrystal does not lie flat. Instead it is sticking up a little bit and there is a gap underneath it. I need to solder the chrystal to the PCB board over a gap so the solder reaches the Gold colored plate. I obviously cannot solder and push down the chrystal at the same time. So how do I do it? Here is an image of what I am trying to do > solder.png
  2. Lestraveled
    May 19, 2014
    1,957
    1,218
    Could you post a real photo of what you want to do?
  3. KL7AJ
    Nov 4, 2008
    2,047
    295
    I would bend the leads into an S shape, close to the body of the crystal. Form them so that there's a bit of downward pressure of the crystal against the PCB when you poke the leads through the holes. The tiny extra lead length shouldn't affect the operation. I'd also solder the body first, before the leads.
  4. hp1729
    Nov 23, 2015
    2,099
    233
    Bend a wire around the body and solder it down.
  5. SLK001
    Nov 29, 2011
    852
    243
    How about simply gluing the crystal down? Or use double sided tape? Applying that much heat to the crystal body does long term damage to the crystal. And if you HAVE to solder it down, you can push it down and solder it at the same time. Just don't remove what is pushing down the crystal until the solder solidifies.
  6. ian field
    Distinguished Member
    Oct 27, 2012
    4,456
    792
    The gum on tape could deteriorate and produce a leakage path.
    Usually its sufficient to just hold the component down and re-melt the solder joints - just repeat until the part is fully flush.
    You can now get Z-axis conductive double sided tape that can be use for such things as attaching flexiprint to all glass LCD modules.
    That would work for earthing a crystal can - but I stand by the warning about gum contamination - maybe die cut generous clearance holes for the leads so the gum can't contaminate them.
  7. SLK001
    Nov 29, 2011
    852
    243
    Would depend on the case. I'm assuming an HC-49 type case, but we'll have to wait for a picture to really know.
  8. hp1729
    Nov 23, 2015
    2,099
    233
    Too much stress on the leads I would think.
  9. SLK001
    Nov 29, 2011
    852
    243
    Again, this would depend on the package. Here's what I think the package looks like:
    Plenty of lead for stress relieving. Also, this package is fairly easy to solder to - if you have to solder it.
  10. jpanhalt
    Jan 18, 2008
    5,699
    909
    Can you reach it with a cloths pin or rubber-band hobby clamp (reach about 2")? That is what I use when I need to hold something down.
    John
  11. hp1729
    Nov 23, 2015
    2,099
    233
    Yep, plenty of lead length to bend it better. The original picture just indicates a single bend, not a stress free "U" (up first then down) that would allow for holding it down while soldering.
  12. spinnaker
    Oct 29, 2009
    5,081
    1,181
    The OP has only one post. Has not bothered to post back with a followup. It is pointless to continue this thread till the OP gives feedback otherwise all other posts are speculation.
  13. GopherT
    Nov 23, 2012
    6,315
    4,040
    Good point, I will wait to post the crystal planing and leveling device I designed for him until he returns.
  14. Mark Smith 1
    Feb 19, 2016
    The chrystal cannot have any solder on top of it. Only the side can have solder(the side next to the Gold colored plate). The solder from the Gold plate to the side of the chrystal has to be a joined in a concave shape.
  15. SLK001
    Nov 29, 2011
    852
    243
    I'm sorry, maybe I'm not getting it. What is a chrystal?
    And where is your photo of this new device?
  16. ErnieM
    Apr 24, 2011
    7,439
    1,627
    Thread is useless until the crystal package is disclosed.
    There is no H in crystal.
  17. ian field
    Oct 27, 2012
    4,456
    792
    Only if you're a ham-fisted numpty.
    GopherT likes this.
