how to slowly glow up LEDs
Discussion in 'The Projects Forum' started by bchen, May 7, 2011.
  1. bchen
    Mar 26, 2011
    Dear all, I would like to create a simple circuit that can slowly (takes about 1 second to) glow up a LED. I have tried to connect a capacitors, resistors and LED in series but it doesn't work.. Any suggestions?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    LED fade in/ fade out
    Introduction and PaintCAD , Chapter 12
    There are many ways to do this. You need to define your application better. I suspect a simple transistor added to the rest of the mix will get you where you want to go.
    The first post I showed is a comedy in misunderstandings, but we eventually got him where he wanted to go.
    In the second link (which is an article and tutorial I wrote) look for "comet trails" in Chapter 12.
