how to simplify this..
Discussion in 'Homework Help' started by transgalactic, May 19, 2008.
  1. transgalactic
    Thread Starter Active Member
    Apr 29, 2008
    74
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Try this simplification on for size.
    hgmjr
  3. mentaaal
    Oct 17, 2005
    451
    Just out of curiosity, what does the diamond symbol mean?
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    The diamond shaped voltage source represents a dependent voltage source. In this case the voltage source Vr depends on the voltage across the 4 ohm resistor in series with the 20V dc power source.
    hgmjr
  5. transgalactic
    Apr 29, 2008
    74
    i want to find a simpler way to represent each current
    do you want me to write currents for the PDF file circuit that you added??
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    Actually, the circuit that I appended to the document is equivalent to your circuit. I just rearranged it to simplify the analysis.
    hgmjr
  7. transgalactic
    Apr 29, 2008
    74
    i am not aloud to rearrange the circuit in the test
    what is the simplest way to right currents in my circuit
    because using my way for which in each node it splits into two new ones
    i get 11 variables
    is their any simpler way??
  8. ramakrishna_406
    May 20, 2008
  9. ramakrishna_406
    May 20, 2008
  10. transgalactic
    Apr 29, 2008
    74
    i did here nodal voltage analysis
    i got 11 variables
    thats impossible
