How to shut down (LT) Spice after calculation
Discussion in 'Programmer's Corner' started by arben, Mar 10, 2014.
  1. arben
    Mar 10, 2014
    Hello everyone
    I use Matlab to create netlists for LTspice, then I call LTSpice multiple times form Matlab using the "system" comando. Until now, I have to quit every LTSpice instance manually after calculations. Is there a way to do this automatically?
  2. ActivePower
    Member
    Mar 15, 2012
    155
    23
    I'm not sure if this fits the bill - just shooting in the dark here, but you could use MATLAB's timers to start and terminate system processes after specified amounts of time. This is just a hack but it'd probably work.
    To check, I just wrote a MATLAB script to automatically start and end a process under Windows 7.
    Here's the script (in entirety):
    Code ( (Unknown Language)):
    1. % HandleProcess.m
    2. % MATLAB Script to automatically initiate and close system processes
    3. % OS: Windows 7 (64-bit)
    4. %
    5. % System commands:-
    6. %   View all processes:     tasklist
    7. %   Kill process by name:   taskkill /IM
    8. %
    9. % Usage (from Command Line or another script)
    10. %       >> global PROCESS;
    11. %       >> PROCESS = 'ltspice.exe';
    12. %       >> HandleProcess();
    13.
    14. %% Function to start process
    15.
    16. function [] = HandleProcess()
    17.
    18.     sysTimer = timer('TimerFcn', @(x, y)pause(1), 'Period', 10);
    19.
    20.     % Start system process (Important: Append '&' to make it a background process otherwise timer won't terminate)
    21.     global PROCESS;
    22.     proc = [PROCESS, ' &'];
    23.     system(proc);
    24.
    25.     sysTimer.StopFcn = @(~, ~)KillProcess;
    26.     start(sysTimer);
    27.
    28. end
    29.
    30. %% Function to kill processes
    31.
    32. function [] = KillProcess
    33.
    34.     global PROCESS;
    35.     cmd = 'taskkill /IM ';
    36.     command = [cmd, PROCESS];
    37.     disp(command);
    38.     disp('Killing process!');
    39.     system(command);
    40.
    41. end
    42.
    Maybe you could adapt it for your purpose.
    Hope this helps.
  3. tshuck
    Oct 18, 2012
    3,531
    675
    Running it in batch mode might make it exit on completion (I'd have to look to be sure).
    There is a batch mode command line option (-b, if I remember right).
