How to show ADC results on 7segment display
Discussion in 'General Electronics Chat' started by ramses, Nov 5, 2013.
  1. ramses
    Nov 5, 2013
    17
    i work on a range finder project. I need to help(source or suggestions) for displaying results of ADC( Analog to Digital Converter). I wonder how can i show ADC results on seven segment display. Is there any special integrated circuit for this situation?
  2. adam555
    Aug 17, 2013
    858
    39
    The easiest way is through a BCD-to-7segments Decoder (e.g. a 4511 IC)
    ramses likes this.
  3. crutschow
    Mar 14, 2008
    13,488
    3,372
    There are also some ADC's that directly drive a digital display such as these.
    ramses likes this.
  4. ramses
    Nov 5, 2013
    17
    I need to show results in 2 or 3 digits seven segment display(results are bigger than 9). Is it possible to construct multi-digit 7segment display with 4511 IC without using any microcontroller or microprocessor??
  5. MrChips
    Oct 2, 2009
    12,625
    3,451
    You can buy single chip ADC with BCD outputs.
    For example, MAX1496 (pdf file).
    ramses likes this.
  6. adam555
    Aug 17, 2013
    858
    39
    You can also add a BCD counter to multiplex various digits. Like this...
    I never tried it, so I'm not the best person to advice you; but you can find more info here: http://www.elecpod.com/circuit/lighting/2012/03287459.html
    ramses likes this.
  7. ramses
    Nov 5, 2013
    17
    I will use 8 bit ADC. SO I think that BCD to 7segment display is useless for the project. Results must be shown from 0 to 255. So i have to use 3 seven segment display. For this reason, can you suggest me any integrated circuit to drive 7segment display according to 8 bit?
  8. MrChips
    Oct 2, 2009
    12,625
    3,451
    You can do it with three 74185 and three 7447 chips or with one PLA or MCU chip.
    ramses likes this.
  9. BobTPH
    Jun 5, 2013
    806
    121
    A 14-pin microcontroller could replace the ADC and all other chips, needing only 3 transistors for digit drivers to enable a 3 digit output. But then, you need to have the tools and experience to program it.
    Bob
  10. ramses
    Nov 5, 2013
    17
    Thanks. I think your suggestion is more usefull for my project and the basic configuration is like this:
  11. MrChips
    Oct 2, 2009
    12,625
    3,451
    It is a 74185, not 74184.
  12. Yin WEi
    May 14, 2016
    May i know what is the model of adc u used for this circuit?
  13. WBahn
    Mar 31, 2012
    18,085
    4,917
    Don't hold your breath waiting for a response-- the thread is more than two years dormant and the TS hasn't been seen in over a year. However, the TS (and other participants) should receive an e-mail notifying them of your post, so you can always keep your fingers crossed.
