How to show 4-bit binary number on 2 7-segment display
Tity
Joined Dec 13, 2016
Hi all,
Now i have 4-bit binary number and want to show it on two 7-segment display by logic gates..
such as, this number (1000) want to show it as (08) first 7-segment contains (0) and second one contains (8)
the same with (1100) will be shown as (12) .. (1) on 1st display and (2) on 2nd display
How can i do that?? i did it on a single 7-segment, but i want it on two 7-segment not only one. i tried many times but i can't do it :\
Please HELP!
Thanks in advance.
djsfantasi
Joined Apr 11, 2010
9,156
This is a bit complicated. There used to be a chip that did it for you but it is no longer available. Nowadays, the solution to this problem is likely a microcontroller. However, if you wish to do it in hardware rather than software, search online for "binary to BCD circuit"
WBahn
Joined Mar 31, 2012
29,979
Hi all,
Please HELP!
Thanks in advance.
Since there are only fifteen possible inputs, you could just use a look-up table.
You can also decode the binary value into a two-nibble BCD value and send that into two binary to seven segment decoders.
Since the IS homework help, it's YOUR turn to show your best attempt.
