How to shift in time a servo pulse
Discussion in 'The Projects Forum' started by Bontempos, Jan 30, 2016.
  1. Bontempos
    Jan 30, 2016
    I am having this idea where I connect servos in a row, and send information only to the first servo. I connect them in a way the next servo reads the pulse from the previous servo. It works fine, but I wanted to add a "delay" to this chain, so the next servo would read the previous servo pulse with some delay and so on.
    I have been checking some projects with 555 but I believe this is not what I need. Shift registers also occurred to me, but I guess current servo must save information from previous servo, shift the whole data and than output it...
    Any way to do it without adding a microcontroler to control each servo?
    Thanks in advance!
  2. tracecom
    Apr 16, 2010
    3,878
    1,396
    One microcontroller can control multiple servos by dedicating one uC I/O pin to each servo. The uC can be programmed with whatever delay you want.
  3. Bontempos
    Jan 30, 2016
    Thanks for your reply!
    I understand one micro controller can drive several servos but for design purposes I need each servo block to be independent. They are connected to each other but sharing the same terminal parts. Do you think I can make this work with a pic 12f629 ? I will look for some project to learn how to use it
  4. Bontempos
    Jan 30, 2016
    In the end I am using a microcontroler (attiny85) to record an array of angles based on the receiving pulse from a target servo and than creating an output with desired amount of delay to move the current servo.
    Thanks!
