<snip>
anyway, my current setup is using a AAA battery for power.
so, my SFH5110 is correctly setup reading an output of 1.369V
but it doesn't go down at all when the IR led is on.
<snip>
1 AAA Battery is only roughly 1.5 Volts, if the SFH5110 requires a voltage of 5 Volts, then you are way off on the power requirements for the device. Try using at least 3 AAA's (roughly 4.5 Volts) and see if that makes a difference.
B. Morse
