How to set frequency range?
Discussion in 'Homework Help' started by Theory, Nov 7, 2015.
Thread Status:
Not open for further replies.
  1. Theory
    Nov 3, 2015
    28
    Hi sirs/madams,
    I have a hard time setting my highest freq for my Class A amplifier (CE configuration), i learned that Couplings and Bypass are used to set the lowest freq (correct me if im wrong - i learned this through internet :) ). And i dont have any idea how to set my highest freq and i dont even know what i should do to control it. :( Can you guide me somehow? I would like to have 300Hz to 30kHz range.
  2. MrAl
    Distinguished Member
    Jun 17, 2014
    2,547
    512
    You mean like a low pass filter?
    In general, an increase in a parallel capacitance lowers the high end response while an increase in a series capacitance raises the low end response.
  3. Theory
    Nov 3, 2015
    28
    @MrAl Yes sir. I just found out that through internet that in a class A amplifier ( BJT Transistor), i can set my lower cutoff freq through the Couplings and bypass. It was stated that Cc and Cb act as a high pass filter, is that correct sir?
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    You already have a thread for your amplifier:
    Amp FAIL!
    Bertus
Thread Status:
