Why did you suggest this? To keep the solenoid's 500 mA drain from going through the 7812, causing it to heat?Another thought: Use 7812 , 12 V output for logic ckt & connect solenoid to un regulated supply, might add 5Ω, 3 to 5 W in series.
hmmm, I reckon I'll just have to settle for 2,4,6,8, & 9Digital things start counting at zero.
So the first cup of coffee has no coffee in it.
The second cup has 1 cup of coffee.
...Then the 10th cup of coffee also has 1 cup of coffee in it plus has 8 cups of coffee spilling all over the place!
Thanks for the input on that.@ 1 A & 4 in. # 28 will drop about 21 mV- not much of a problem, mechanical strength questionable, but in a bundle I see no problem.
And another ventures to the Dark Side.Anyway, I'm not going to bother making another board, I'm switching gears and bought an Arduino! So when it gets here I'll see what I can do with it. Thanks for all the help here! I've learned a lot.
Thread starter | Similar threads | Forum | Replies | Date |
M | problem with running ic 4040 in pspice | PCB Layout , EDA & Simulations | 3 | |
K | LED blinking using 555 and 4040 | Homework Help | 17 | |
10Hour Timer using a 555/4040 | Digital Design | 25 | ||
G | 4040 and 2716 EPROM; is this the way to set it up? | Digital Design | 41 | |
B&K 4040 Function Gen Manual?? | Datasheets, Manuals & Parts Identification | 18 |
