How to separate grounds
Discussion in 'Embedded Systems and Microcontrollers' started by signalflow, Mar 18, 2014.
  1. signalflow
    Mar 12, 2014
    50
    I am trying to separate grounds for a noisy side of an optocoupler and a clean side of the optocoupler. So I would need gnd1 for clean side and gnd2 for noisy side.
    I have a bridge rectifier converting the input AC voltage to DC which one of the points on the rectifier is my ground (call it gnd1). Then I have some voltage regulators. The voltage regulators are tied to this same ground (gnd1). Can I not tie one of the voltage regulator's gnd pins to gnd1 and just call this pin a new gnd (say gnd2)? But it's really just a floating pin, then, right? I'm not sure the voltage regulator would work in this case.
    I just can't see how to create a separate ground. Any help is appreciated. Thanks.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    There is some ambiguity in your request. For the grounds to be isolated with an optoisolator, you need two different power supplies with no possible connection between their grounds; not on the board, not in the house not with a mouse.
    To separate grounds on a board so that noise on one has to try really hard to affect the other one, you use routing and layout. Start with a common ground as close to your power supply as possible. From that single point common ground you run a trace to the "noisy components". From the single common ground you run an entirely separate ground trace to the "quiet components". You must make sure that "noisy ground" and "quiet ground" have only the single point in common as close to the power supply as is humanly possible.
  3. signalflow
    Mar 12, 2014
    50
    I am talking about what you state in your first paragraph (using an optoisolator with 2 separate power supplies + grounds). So basically I would need 2 bridge rectifiers + regulators, etc. I was thinking I could use 1 bridge rectifier and then 2 regulators to create the 2 power supplies, but sounds like I would need 2 rectifiers to create the 2 separate grounds. Does that sound right? What I mean is the 2 regulators would create the 2 separate Vdd lines but with only 1 bridge rectifier I would still only have 1 ground.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yes that is correct. There is absolutely no point in using an optoisolator to "isolate" circuits if they have a common ground at the Rectifier/Capacitor. You can of course use them for "level shifting" or "polarity inversion" if you like.
  5. signalflow
    Mar 12, 2014
    50
    I just don't have room for another power supply.
    So you don't think having an optocoupler with the same ground but different Vcc lines will help at all? Seems like at least some of the noise would be eliminated that comes through the optocoupled lines even though some of that noise will get through the gnd.
  6. John P
    Oct 14, 2008
    1,638
    225
    If the grounds are joined, I don't think you'll gain anything with an optocoupler. The usual way to handle something like this is to separate the components into digital and analog (maybe with "high power" as a third section) and have each one on its own ground plane, with the grounds connected at only one point. Keep traces associated with each section within that section, and make the connections between them as few as possible, and just on the boundary.
    I've never done this myself, though I've heard of it: you can have the boards physically separated, with fiber optic connections between them. That sounds like a pretty desperate situation!
    Papabravo likes this.
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    This is what I described in the 2nd paragraph of my original post. It really works great with things like stepper motors and sensitive comparators (LM311) monitoring phase currents. Trust me on this one.
  8. Brownout
    Jan 10, 2012
    2,375
    998
    You can further decouple the noisy and quiet ground by adding filtering between them. Connecting the noisy ground to the center point via a choke might help to keep the noise contained. Also, extra decoupling caps on the quiet side may help.
