how to select the right mosfet?
Discussion in 'General Electronics Chat' started by brucester, Jan 9, 2013.
  1. brucester
    Dec 24, 2012
    19
    I want to pulse 9volts 200 times per second controlled by a 5 volt signal.
    What would be the best mosfet for me?
  2. bertus
    Administrator
    Apr 5, 2008
    15,800
    2,386
    When you are switching with a 5 Volts gate voltage, you should look for a logic gate mosfet.
    How much current needs to be switched by the fet on the 9 volts side?
    Bertus
