How to select Micro-controller
Discussion in 'Embedded Systems and Microcontrollers' started by Athulmsr, Jul 11, 2013.
  1. Athulmsr
    Jul 5, 2013
    7
    I need to select a PIC33F microprocessor. My requirements are:-
    1.Need to connect a LIN,CAN or K-Line Transceiver(I didn't find any transceiver for K-Line. Hope LIN transceiver is compatible)
    2.Need to connect to a 16 by 2 LCD
    3.Need to connect to max 4 touch switch(need touch controller)
    4.Need a bluetooth interface
    Can someone suggest me some lowcost solution?
    Hope somesone could help...
  2. tshuck
    Oct 18, 2012
    3,531
    675
    Check out microchip's site, they have a product selection tool that will help you pick a PIC:))), I think it's called the MAPS tool...
    Athulmsr likes this.
  3. Athulmsr
    Jul 5, 2013
    7
    But I need to find a proper selection of the interfaces to the components to reduce the I/O pins and hence the cost to do that... Please help me in selecting them...
  4. tshuck
    Oct 18, 2012
    3,531
    675
    There are Bluetooth modules that work on UART, or SPI, along with 8 pins for a character display, CAN is two lines and lots of controllers have touch switch capabilities...
    I think you need to define your other hardware before you can devise a way to control it...
  5. Athulmsr
    Jul 5, 2013
    7
    Thanx for the reply, it was useful. Here I would like to control all the module by micro controller...
  6. donpetru
    Nov 14, 2008
    186
    25
    PIC33F is not the best choice. As I studied the market, I would like to say that the best choice at the moment, from the view of price / performance, are STM32 ARM. For example, see STM32F407VGT6:
    http://www.st.com/web/catalog/mmc/FM141/SC1169/SS1577/LN11/PF252140
    STM32F407VGT6 some features:
    - 3×12-bit, 2.4 MSPS A/D converters: up to 24 channels and 7.2 MSPS in triple interleaved mode;
    - 2 × CAN interfaces (2.0B Active);
    - Advanced connectivity: USB 2.0 full-speed device/host/OTG controller with on-chip PHY; USB 2.0 high-speed/full-speed device/host/OTG controller with dedicated DMA, on-chip full-speed PHY and ULP
    and much more...
    So, think and choose well.
  7. Athulmsr
    Jul 5, 2013
    7
    Thnaks for the post. I think it is good, but we could make much better configuration using some low cost pic with just enough requriements...
  8. raja.afiq
    Jul 17, 2013
  9. ananthapriya
    Jul 18, 2013
    10
    Hey Why you have to choose ARM processor? because of special ARM having inbuilt with CAN option.So i think ARM processor is suitable.when you buy ARM processor you don't need to purchase can controller for separately.This is my thought!!!!!!!!!!!!!
    BacklinksVault
  10. Athulmsr
    Jul 5, 2013
    7
    Even though CAN module is present in a microcontroller, a transceiver is required to interface in an automobile application.
    Now cananybody suggest how to select the microcontroller for CAN implementation which will suppot as well the peripherals too
