How to select DC capacitor?
Discussion in 'Off-Topic' started by mohanthiyagu, Jul 11, 2013.
Thread Status:
Not open for further replies.
  1. mohanthiyagu
    Jul 11, 2013
    I have 2 DC motors of same capacity coupled with each other. I have plan to run one motor as motor and other one as generator. Motors armature and field connected to the DC source as well as generator armature(parallel). I plan to run the set up without power source(motor runs generator and generator runs motor). After starting the motor the set up starts rotating. Generator giving output. after switch off the motors power supply total set up stops. Whether this is technically possible? If so i plan to put onr capacitor parallel to the MG set. How to calculate the capacitor value and wattage?
  2. #12
    Nov 30, 2010
    16,705
    7,358
    It's called, "perpetual motion". It is not possible, it is not allowed on this site, and you can't calculate the capacitor for infinity.
  3. wayneh
    Sep 9, 2010
    12,406
    3,256
    Not even close. It doesn't matter what capacitor you use, since it won't work no matter what.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    As per Chapter 6 on overunity devices of our Terms of Service, this thread is closed.
Thread Status:
