How to select bypadd capacitor to filter 1.4MHz?
Discussion in 'General Electronics Chat' started by tprofits, Mar 26, 2013.
  1. tprofits
    Mar 25, 2013
    6
    I have a SMPS that has a 1.4MHz transient I'm trying to shunt to ground. How do I select the correct capacitor to filter 1.4MHz?
  2. crutschow
    Mar 14, 2008
    13,482
    3,370
    Capacitors filter a broad range of frequencies with their impedance inversely proportional to frequency and capacitor size. You want a capacitor with a low ESR and inductance, such as ceramic types, perhaps in parallel with a larger electrolytic capacitor.
    Such transient noise from an SMPS is very hard to filter and may require a inductor along with the capacitor or perhaps a feedthrough filter or common-mode choke. Without knowing your configuration, it's difficult to make better recommendations.
    Where is the noise appearing?
  3. tprofits
    Mar 25, 2013
    6
    I have the following images. One is a screen shot of the transient. The second is the circuit. I'm thinking a capacitor in parallel with the 68uF might help. But, I'm not sure how to calculate the correct capacitor?
  4. crutschow
    Mar 14, 2008
    13,482
    3,370
    There is no "correct" value. You just need a very low impedance capacitor to high frequencies which is typically provided by small ceramic types of 0.1μF. The problem generally is the inductance of the connections to the capacitor. Even a mm of wire has a significant inductive impedance to high frequencies, thus the best way to connect the capacitor is a surface-mount type connected directly to the ground plane with the trace being filtered running through (in and out of) the other capacitor pad.
    Alternately some type of feed-through capacitor connected directly to a grounded chassis can help, or an added inductor in series with the output with another capacitor to ground.
  5. MrChips
    Oct 2, 2009
    12,625
    3,451
    Putting an inductor in series with a capacitor is not a good idea. This is a resonant circuit.
    100μH in series with 68μF will resonate at 2kHz.
  6. kubeek
    Sep 20, 2005
    4,688
    806
    I bet that is a part of a buck switching converter.
  7. tprofits
    Mar 25, 2013
    6
    crutschow - I was using 4" leads of wire soldered to my PCB. I'm going to add a 0.1μF cap in series with the 68μF (with a short lead wire). I'll record the results. Thanks!
  8. kubeek
    Sep 20, 2005
    4,688
    806
    4 inch wires between the transistor and the output filter? That will hardly ever work well.
  9. crutschow
    Mar 14, 2008
    13,482
    3,370
    As long as there is no source of 2kHz to excite the resonant circuit, it shouldn't be a problem.
  10. crutschow
    Mar 14, 2008
    13,482
    3,370
    4" wires are a no-no.
    And you want the 0.1μF cap in parallel not in series.
    How short is "short"?
  11. MrChips
    Oct 2, 2009
    12,625
    3,451
    Yes, sorry about my post. I noticed all SMPS do the same thing.
  12. tprofits
    Mar 25, 2013
    6
    Thanks for the assistance! I tried a 0.22μF, then a 0.1μF and then a 0.01μF ceramic capacitor in parallel with the 68μF capacitor. It didn't fix the transient. Would you mind double checking my scope calculation. Am I targeting in on the right frequency (1.33MHz)? The capacitor wires measured 4.5mm.
  13. kubeek
    Sep 20, 2005
    4,688
    806
    Can you post a picture of your setup and the whole schematic?
  14. tprofits
    Mar 25, 2013
    6
    Here is the schematic. Does this help with any ideas on how to reduce the transient or the ripple amplitude?
  15. kubeek
    Sep 20, 2005
    4,688
    806
    How long are the ground and power traces to the diode, induictor and output cap?
    Can you post a picture of the physical layout?
  16. tprofits
    Mar 25, 2013
    6
    Here is the PCB.
