How to select a NTC(Thermistor) ?
Discussion in 'General Electronics Chat' started by sneha.123, Jun 11, 2014.
  1. sneha.123
    Jun 11, 2014
    Hello
    I Have a design that needs to have very low resistance 0.2 ohms at -25 deg.Can i get help on how to select the same.
  2. R!f@@
    Apr 2, 2009
    8,786
    771
    Hello sneha. Welcome.
    I am sorry I haven't yet seen one but may be other members had. Give it some time for others to respond.
  3. Dodgydave
    Jun 22, 2012
    5,143
    768
    Think the lowest ntc is a 2k2 @ 25C, ntcs go higher in resistance with lower temps, what is the design for?
  4. sneha.123
    Jun 11, 2014
    It is used to to see when the cooling ability of the system breaks down.By knowing the power the system can withstand the resistance is calculated to 0.2ohms.I need to select the NTC accordingly.
  5. #12
    Nov 30, 2010
    16,665
    7,310
    I can bid at .7 ohms, but better to post the literature.
  6. sneha.123
    Jun 11, 2014
    Thanks for the inputs.I will check if these suit my application.
  7. pwdixon
    Member
    Oct 11, 2012
    488
    56
  8. sneha.123
    Jun 11, 2014
    Yes my application is for temp measurement and not circuit protection.
  9. pwdixon
    Member
    Oct 11, 2012
    488
    56
    Why must the thermistor be such a low value? Normally in most measurement scenarios people want to have a large thermistor value to reduce self heating and save power on the measurement system itself.
  10. joeyd999
    Jun 6, 2011
    2,756
    2,920
    Ummm...not always. Driven with a constant current, lower R results in proportionally less power, as P=IR.
    OTH, I am not sure the OP understands what he really needs. 0.2 ohms at -25C to seems quite unusual.
