How To Save Signal On I2c
INX
Joined Apr 30, 2007
Umm, hey again all...i am working on saving data "signals" on an I2C memory then i need data i need to call each signal apart by example...when i push "1" i want to call ECG SIGNAL ...then on 2 EMG and so on so i need ideas about saving this data and how to call it....
hope u can help thank you for everyone....
beenthere
Joined Apr 20, 2004
15,819
Assign blocks of the memory to each category. Use a table of address offsets to combine with the desired address so a call into the ECG section uses a different part than a call into the EMG section.
Or use separate memory ic's for each data stream.
