Hey guys,
I was wondering if anybody can help me out with this one.
I took out a small steel rod. the one you usually find in a 3-rod cable and the third one is ground. So i took that out (ground rod) and i want to install it somewhere and run +5V through it. In other words, i want that rod to conduct voltage to whatever object its installed in. Does that make sense? :S
Thank you in advance
