A stepper motor requires that the drive signals to each of its four drive lines be time sequenced correctly to result in motor shaft rotation. Just connecting a DC signal to any one of the four lines of your unipolar stepper motor will not result in motor rotation.Do you need to have a microcontroller hooked up to the Stepper Motor, or can you run it just plugged into a DC power source? If so, how do you hook up a 4 wire Stepper Motor to a DC power source?
have you tried a google? i found this which while it is tailored to a specific chip, details some of the methods of driving, the signals at least.. a starting point perhaps.Do you need to have a microcontroller hooked up to the Stepper Motor, or can you run it just plugged into a DC power source? If so, how do you hook up a 4 wire Stepper Motor to a DC power source?
by Jake Hertz
by Jake Hertz
