how to rotate a metallic rod in clock and anti-clockwise directions
Discussion in 'The Projects Forum' started by shaheer khan, Nov 20, 2012.
  1. shaheer khan
    Nov 20, 2012
    We are working on a project, in which a metallic rod (shaft) need to rotate in clock wise and anti-clockwise (Say 10 degree to both sides) at very faster rate to achieve a penetrating vibrational effect. Our main challanges are,
    1) This product need to take higher torque and hence may need effective gear system which is capable of rorating both sides.
    2) This has to be a cost effective one. Hence we are unable to use the Stepper motor and all.
    It will be appriciated if you could suggest some approches to proceed on this.
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Ten-degree oscillation is not a lot and hence this should be easy to do.
    Use an ordinary high speed DC motor with a small disc or short arm mounted to the axle.
    On the disc or arm is a small post or freewheel bearing mounted off centre.
    A freewheel bearing is better for reduced friction and minimal wear.
    This small wheel is inserted into a long slot in another wheel on the shaft that you wish to rotate.
    I can provide a drawing if this is not clear.
  3. tshuck
    Oct 18, 2012
    3,531
    675
    DC motor with a worm drive will take care of you...
  4. mcgyvr
    Oct 15, 2009
    4,787
    973
    Define "high torque"
    Define "low cost"
    Define "fast rate"
    Why do I feel this is a sex toy...
  5. tshuck
    Oct 18, 2012
    3,531
    675
    Ha! Well, I suppose calling it the worm would be fitting....
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    Not surprising with words like:
    Looks like we'll soon see a new clause in the TOS.
  7. JDT
    Feb 12, 2009
    658
    85
    Stepper motor?
  8. Kirtho
    Jan 18, 2011
    6
    Core sampler? Masonry drill? Oddly enough I am working on something that swings an iron bar back and forth a few degrees. Right now I'm using electric eyes to spot the ends of the swing and I may switch to a chip that detects the angle using a magnetic field. Mouser has it for about a dollar. It's the KMZ41. The first generation of the design used actual electrical contact between the bar and the ends of bolts that I use as bumpers. The second generation is the electric eye. The third generation will probably be angle detection using a Hall effect sensor which will be very precise and may be cheaper.
    I actually am making a piece of iron swing back and forth, although this generation rides on a shaft and isn't attached to it. If I made a longer shaft and attached it to the bar, I would have what Shaheer is talking about.
  9. djsfantasi
    Apr 11, 2010
    2,900
    876
    http://www.youtube.com/watch?v=N8cwbu5wPgk
    Does this video illustrate what you are looking for? If you ignore the top slider, the driver rod is swinging back and forth, depending on where the various pivot points are located. The video is from Wolfram Mathemica.
