When powered on the motor spins clockwise, however I would ideally like to set it up with a 3 position (cw-off-ccw) switch. I bought this motor from Ebay and was told that it is reversible, but am not sure how to do so without burning it out... The wires coming from the motor are black(high speed) red(low) white(neutral) and brown (cap). I have attached the only diagram I have for the motor. From what I've been reading, its direction can be reversed by opening the motor and switching around the start winding and run swinding. I have no idea how to do this. Is these an easier, possibly less complicated solution? Thanks in advance.
