I bought a Dirt Devil Scorpion that just won't charge. It goes past its 24 hours charging time and the light remains red, as if still charging, and even if left longer the power won't last more than 4 minutes. Dirt Devil is replacing it so no problem and this one should be thrown away but then I thought is it possible to make this battery come to life? Under its specs it says: Nickel cadmium 6V 6 amps.
On thing I tried is while charging I removed it from the charger for about 2 minutes then set it on/off/on/off real quick about 6X (having seen this elsewhere for old used batteries) but nothing happened.
Any advice would be appreciated--though as one video suggested, hooking it up to 2 other equal batteries is not the thing I was looking for as an answer.
Regardless, as mentioned, all help would be appreciated.
Or could the charger actually be the problem?
