My First Thread, I apologise for any mistakes.
I have a classic car clock that is running at double speed i.e. 30 sec to do 1 min, it has a very simple circuit and seems to be a larger version of the normal quartz wall clock, it has a coil that needs a momentary 12v pulse every 1 second which reverses 180 degrees every alternate pulse, my issue is that I cannot identify the crystal frequency and the chip is no longer available (please see attached pictures) my original idea was to replace the components, which I did the resistors and capacitors although they were testing fine. I could replace the clock but I want to keep the dials original, I also like a project. Would anyone on the forum have any ideas for a circuit I could use to replace the chip or an equivalent chip as I cannot find it in my old reference books. I have looked at 555 timers but they do not seem accurate enough, I have also found a thread on using a 1.5v wall clock inards but due to the reversal pulse I am having difficulty increasing the output to 12v.
many thanks
Jim
many thanks
Jim
