how to replace lm386 from circuit
Discussion in 'The Projects Forum' started by l1nuxg33k, Oct 30, 2006.
  1. l1nuxg33k
    Sep 27, 2006
    7
    How should I remove the LM386 from the Pixie-2 circuit
    http://www.qsl.net/we6w/projects/pixie2.gif
    so that I could just connect it to amplified computer speakers?
    What would be the signal and ground of the audio output?
    How should I connect the 1N914 and the 0.1uF? :confused:
  2. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    It looks like it's already set up for line audio out.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    I concur with MrMeval. Simply hook up the circuit audio out to your speakers.
  4. l1nuxg33k
    Sep 27, 2006
    7
    No, I meant I want to remove the LM386 from the circuit, in other words remove the audio amp from the circuit and use my own instead.
    To where should I connect the amplified computer speakers and where should I connect the 1N914 and the 0.1uF instead?
  5. l1nuxg33k
    Sep 27, 2006
    7
    anyone know how to do this?
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    What type of audio amp do you wish to use in place of the op amp?
  7. l1nuxg33k
    Sep 27, 2006
    7
    Amplified computer speakers.
    In other words I want to get the unamplified output from this circuit.
  8. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    A "brute force" approach would be to simply take audio from Q2 emmitter. Or from pin 2 of the op amp. Ignor the diode - its job is to shut the op amp down when keying.
    I still recommend using the signal from the Pixie's "audio out."
