How to replace IGBT with Mosfet
hosam
Joined Oct 10, 2008
I have a DC motor speed control board it use this part CT60AM it control 3HP DC motor and it is usualy destroyed for this I want to change it with mosfet .and the flyweel diode how many amper will be.
can any Expert man help me
hosam
Joined Oct 10, 2008
Select a FET whose specs match the IGBT's. Voltage and current are critical. You may have a challenge with the voltage rating if that is significant. here is a link to the datasheet - http://www.datasheetcatalog.com/datasheets_pdf/C/T/6/0/CT60AM-18B.shtml.
The reverse diode needs to match the FET for voltage. Having the motor spec might help with expected current.
thank you for your reply .
the motor is 3 hp , 180vdc , 6.5A at 5400 rpm what The spec of the reverse diode needs for this motor
