I'm working on an old Tube amp and I have a problem I need help with.
This amp uses a 20w 8k power resistor as a bleeder for the screens on the output tubes. The design has this resistor dissipating 18watts.
I want to replace it as it is severely under rated, I also would like to eliminate the heat associated with this device
I would like to use a zener string to provide the necessary voltage drop but I'm having trouble getting my mind around the problem.
The screens are at +380Vdc
The current is at .046amps
The dissipation is 17.48 watts
Thanks for any comments or direction on how to work this out!
Chris
Chris
