how to remove 2Volt offset?
Discussion in 'General Electronics Chat' started by bimbel, Feb 5, 2014.
  1. bimbel
    Feb 5, 2014
    I have a strain gauge application and I use instrumentation amplifier (INA 125) to signal conditioning. At the output of INA I have an offset of 2 Volt.
    Do you recommend a circuit for removing the offset, please?
  2. ericgibbs
    Jan 29, 2010
    2,575
    389
    hi b,
    You need to add an OPA on the output of the INA125 and remove the +2V offset in that OPA stage.
    E
  3. ErnieM
    Apr 24, 2011
    7,433
    1,623
    Pin 5, the reference input, looks like you've nailed it to the source of your 2V offset.
    Move that pin to ground and your offset should go away bye-bye.
