How to reduce the power required of a microwave oven?
Discussion in 'General Electronics Chat' started by sdowney717, Mar 24, 2015.
Thread Status:
Not open for further replies.
  1. sdowney717
    Jul 18, 2012
    398
    14
    I have a 1600 watt microwave oven and I have a 1500 watt inverter. So naturally the oven draws too much current for the inverter to provide.
    Where is the power being drawn out of the transformer, by the wire connection to the magnetron? I think the magnetron is what is the main power consumer?
    What if a large power resistor was put in the rectified line to the magnetron? Would that drop the required current use?
    If I wanted to go from 1600 watts to 1400 watts, or maybe 1200 watts what would I use or do?
  2. Alec_t
    Sep 17, 2013
    5,973
    1,135
    For safety's sake I wouldn't advise messing with a microwave :eek:. There are high currents and very high voltages involved. Get it wrong and the results could have fatal consequences for you and the microwave. Isn't your life worth more than the price of a new, lower power, microwave :)?
    cmartinez and Roderick Young like this.
  3. wmodavis
    Oct 23, 2010
    737
    150
    Connect to the AC power to the microwave through a variac and reduce the AC voltage down to the level that will put the current draw into what your inverter will allow. Then test and see if the microwave will still work properly.
    If not get a higher capacity inverter.
  4. R!f@@
    Apr 2, 2009
    8,791
    771
    Also see the variac smoking.
  5. blocco a spirale
    Jun 18, 2008
    1,461
    370
    Disconnect the magnetron.
  6. KMoffett
    Dec 19, 2007
    2,584
    234
    Get a different microwave. Used ones are cheap on Craig's List or in thrift stores.
    Ken
  7. wmodavis
    Oct 23, 2010
    737
    150
  8. gerty
    Aug 30, 2007
    1,154
    304
    Those variacs cost more then a small microwave...
  9. wmodavis
    Oct 23, 2010
    737
    150
    The OP did not mentioned anything about cost being a criteria he was interested in.
    He was only interested per his post in reducing microwave power so it could run on his 1500 watt inverter.
    Just answering what he asked and not trying to guess between the lines. And better than modifying the microwave internals.
  10. KMoffett
    Dec 19, 2007
    2,584
    234
    Guessing about what's between the lines is a major part of what we do here. Few OPs lay out all the details of what , why, how that actually promotes an easy answer. Usually, they less info they put into the request, the more guesses and off the wall suggestions that will be forthcoming. ;)
    Ken
  11. WBahn
    Mar 31, 2012
    18,087
    4,917
    MOD NOTE: As has been noted, modifying a microwave oven is potentially very dangerous. Running one out of spec may also pose safety issues. The suggestions have already been made to either get a microwave that is compatible with the available inverter or get an inverter that is compatible with the available microwave. Hopefully the TS has gotten some useful information.
    I think that's about as far as the conversation can go without violating the ToS regarding dangerous topics, so I am closing this thread.
    KMoffett and DickCappels like this.
Thread Status:
