How to reduce Over-shoot and Under-shoot Problems?
Discussion in 'General Electronics Chat' started by muthukumar_ece2004, May 26, 2011.
  1. muthukumar_ece2004
    May 20, 2011
    9
    Over-shoot and Under-shoot effect mostly occur in digital gates, sometimes it may affect the noise margin of the gate and even damage the internal FET of the gate IC. My question is How to reduce or avoid this Over and Under shoots effects in Digital Gate ICs?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You can slow the rise and fall times of the signals by adding some resistance and capacitance at the gate inputs. This will limit your bandwidth too, of course.
  3. t06afre
    May 11, 2009
    5,939
    1,222
  4. Ron H
    Apr 14, 2005
    7,050
    657
    No, not for reducing overshoot on digital signal lines.
  5. creakndale
    Mar 13, 2009
    68
    7
    1) Use a ground plane so there's a return current path directly above or below the signal.
    2) Is the undershoot/overshoot real? Measuring fast transition signals requires an exceptionally good scope probe ground lead. Use the shortest ground lead possible. Make sure the scope probe ground wire is making perfect contact with the clip (soldered to it) and the connection to the probe body is clean.
    3) Try grounding the probe to a different ground point to see if it makes any difference.
    4) Add a small series resistor as others have suggested.
    They make electrical ground leads that connect right next to the probe tip so to minimize scope probe induced ringing, under and/or overshoot. Here's an example.
    http://www.testpath.com/Items/Ground-Lead-117-256.htm
    creakndale
  6. Ron H
    Apr 14, 2005
    7,050
    657
    Long traces are transmission lines. In addition to the suggestions above, if the round trip delay of the line is more than the risetime of the signal, matching the source impedance to the transmission line impedance will reduce the ringing substantially.
    If the line fans to multiple destinations, this may not work well.
  7. muthukumar_ece2004
    May 20, 2011
    9
    ok, if we are using oscilloscope to measure something means we ca use a valuable probe to avoid overshoot. But if it is not properly matched, then it may cause seriousness to the IC (either it may damage the IC).
  8. Ron H
    Apr 14, 2005
    7,050
    657
    Overshoot and ringing due to a long oscilloscope ground wire will not damage an IC, since it is strictly a measurement error. Overshoot due to a poorly terminated transmission line can damage an IC, or at least cause it to malfunction.
  9. nigelwright7557
    May 10, 2008
    488
    71
    Decoupling hasnt been mentioned yet.
    This is vital.
  10. Ron H
    Apr 14, 2005
    7,050
    657
    Very good point!
