So sorry. Did not mean to, it is all about not quite knowing how it all works. Is there a tutorial somewhere about using the forum?A thread belongs to the TS (Thread Starter). Now you have your own thread.
Your thread has been split off from here:
http://forum.allaboutcircuits.com/threads/confused-circuit-math-with-resistors-and-voltage.123158/
So you need to drop 30V @1A = 30W
Apply Ohm's Law I=V/R
Power = I x V
Hence you will need a 30Ω resistor rated for more than 30W, i.e. about 50-100W
Think of a 30v, 30W light bulb.
That is how hot it is going to get.
Three 12v 15W light bulbs in series will do it.
If this is mains AC, use a step-down transformer.
by Duane Benson
by Jake Hertz
by Jake Hertz
by Duane Benson
