How to recover corrupted database file
Discussion in 'Computing and Networks' started by oliwialosha, Oct 4, 2015.
  1. oliwialosha
    Oct 4, 2015
    I run MSDE on a Windows XP Server and i found that my database was marked as "suspect" by Enterprise Manager and its icon become gray.
    I detach that database and try to re-attach it but there is an error as the following:
    Error 3624:
    Expression: rowLength >= offset + deleteLenght
    SPID : 56
    Precess ID:1612
    After that, I uninstall the MSDE and re-install new MSDE SP4 and try to re-attach the database file again and there is still an error. I also encounter the same error with MS SQL 2000 Server
    Remark: I have all the database file (database.mdf and database.ldf).
    Is there anyway i can recover the data from that database?
  2. AdamHenriksen
    Aug 4, 2016
    Corruption in SQL server database can happen due to any uncertain like virus attack, power failure, hardware issue, OS malfunction, and sudden system shutdown, so on. When a SQL server data file (.mdf) is corrupt then DBAs can try several methods to repair and recover data from it.
    • Run DBCC CHECKDB: It checks & reports all the error message in error log, if there is any problem with the database. Try to analyze & understand the error message logged in the error log. Re-run DBCC CHECKDB with the recommended minimum repair option to repair the file.
