How to read schematic for potentiometer?
Discussion in 'General Electronics Chat' started by dmc0162, Dec 11, 2011.
  1. dmc0162
    Thread Starter Active Member
    Dec 13, 2007
    51
    Sorry for the newbie question, I don't have any experience with this kind of stuff. Here is the schematic I am working with:
    I am soldering it all together on a little PC board from radioshack. I just need help with the pots. The pots I bought have 3 connectors on them, and look just like this:
    I am confused as to which of these prongs corresponds to the schematic (which pins are what). If anybody could lead me in the right direction, I would really appreciate it. Thanks!
  2. ajm113
    Member
    Feb 19, 2011
    176
    5
    http://www.allaboutcircuits.com/vol_6/chpt_3/6.html
    Read some of the tutorials on here, you will learn some very cool things. ;)
    The lines connected to the middle terminal (the arrow) of the pot on the basically means that left or right terminal is connected to the middle one.
  3. Kermit2
    Feb 5, 2010
    3,849
    965
    Almost all of them are made like the picture. Use a meter to get resistance readings with the wiper in different positions to be sure.
  4. spinnaker
    Oct 29, 2009
    5,074
    1,176
    Pretty much just as they look in the schematic. The center goes to your switch, one end goes to ground the other to the cap.
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    It should be noted that you may choose to connect the ends of the potentiometer in either orientation as already mentioned. The difference between the two orientations will be the direction of rotation on the pot's shaft that will represent an increase in the potentiometer.
    hgmjr
  6. dmc0162
    Dec 13, 2007
    51
    Thanks guys! Thanks for the link to the tutorials, also.
