How to read ripples in DC without Oscilliscope, or any other analyzer!
Discussion in 'Homework Help' started by hamza, Dec 26, 2007.
  1. hamza
    Feb 8, 2007
    6
    I've been looking everywhere for the answer, but I really can't find it.
    What is the method of measuring, or checking or even just analyzing the "ripples" in DC without the use of any analyzer device like the oscilloscope?
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    If you know component values, you can calculate an estimate of ripple based on them.
  3. hamza
    Feb 8, 2007
    6
    oh thanks for replying! this is actually an assignment which I have to submit by tomorrow. There are no provied component values or any other things like that. Just a single question. I can't find out because previously I was just into finding this out with the oscilloscope!
    Can you tell me what values should be known, and any relation (formula) which can be used to measure the ripple?
  4. JoeJester
    Apr 26, 2005
    3,401
    1,218
    You place your oscilloscope in the AC mode. Trigger the oscilloscope with line or whatever the generates the basic frequency before the diodes.
    The ripple will be synchronous with the trigger signal.
  5. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    Place your meter in AC mode and you can read the AC component.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Not all meters (particularly old ones) will block the DC component.
    If you use a low-leakage capacitor on one of the test probes, it will block the DC component, but pass the effects of the AC component. If the ripple is a pure sine wave, then the AC scale of a true RMS meter will give you the RMS (average) voltage, and the peak-peak voltage will be the RMS reading multiplied by 1.414 (not exact, but close.) If the ripple is other than a pure sine wave, the RMS reading will be off depending on how distorted the sine wave is.
  7. techroomt
    May 19, 2004
    198
    a multimeter will measure the ac component of a signal as mrmeval explained, with a few exceptions:
    1. an ac meter (multimeter) will "read" the rms value (not average)
    2. the meter is designed to read 60 hz, so anything else will provide error. you can go to "freq" if the meter has that function and read the frequency
    3. anything other then pure sine wave will also provide error
  8. hamza
    Feb 8, 2007
    6
    oh ya! this solves my problem! thank u all!! :)
