How to read from RS232 into ATMega64
Discussion in 'Embedded Systems and Microcontrollers' started by premsuku, Aug 19, 2008.
  1. premsuku
    Aug 19, 2008
    I am trying to read the message entered from 1 hyperterminal connected to UART1 and write that message into another hyperterminal connected to UART0.
    Please help if some one know how to do this
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
    You can use a null modem cable
  3. premsuku
    Aug 19, 2008
    Thanks for the reply, could you explain how I can program that in c
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Do you have a schematic and any starting code at this point?
    If so go ahead and post it.
    hgmjr
  5. premsuku
    Aug 19, 2008
    Thanks for the reply I found the solution..
    #include avrlib/uart2.h
    main(){
    uartInit(); // initialize UARTs (serial ports)
    uartSetBaudRate(0, 115200); // set UART0 speed to 115200 baud
    uartSetBaudRate(1, 115200); // set UART1 speed to 115200 baud
    timerInit(); // initialize the timer system
    while(1){
    rprintfInit(uart0SendByte); // configure rprintf to use UART0 for output
    char c = (char)uart1GetByte();
    rprintfChar(c);
    timerPause(500);
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    That is good news.
    How do you like designing with AVR microcontrollers?
    hgmjr
