How To Protect A LED From Reverse Polarity
haberdasherylondon
Joined Mar 11, 2009
Hello.
I'm using a 9V battery source to power 2 LED's each with a 3.5V forward Voltage. I need to protect the system from reverse polarity that might harm the LED's. I imagine that I should use a zener diode to do this, but I don't know how to specify the right diode.
Can someone help me?
-Dan
bertus
Joined Apr 5, 2008
22,277
A diode in series with the leds will help.
A standard led will hold at a reverse voltage of about 6 Volts.
Greetings,
Bertus
Wendy
Joined Mar 24, 2008
23,421
Or you can put a conventional diode back biased compared to the LEDs. If you do reverse bias them the conventional diode will soak up the current and drop 0.7V, which most LEDs can handle OK.
