How to properly test STP9NK50ZFP transistor mosfet
rastaman46
Joined Nov 17, 2011
75
Hi all again.
How to properly test STP9NK50ZFP transistor mosfet using digital multimeter what readings should I get??
Now if I connect in this order
(S) to (Negative) Then (G) to (positive) result LO
(S) to (Negative) Then (D) to (positive) result LO
(S) to (Negative) Then (G) to (positive) and then (D) to (positive) result is still LO
All done in diode testing mode is here I missing something???
Thanks everyone
REgards
dl324
Joined Mar 30, 2015
16,943
You can't "test" a MOSFET with the diode test function on a meter. The only PN junction in a MOSFET is the parasitic diode across the S/D.
