Hi!
I use the following:
-PIC16F877A microcontroller
-GRAYHILL 25LB22-H MECHANICAL ENCODER as a rotary encoder
I have the following issue:
Because of the fact that the rotary encoder has only 16 pulses, I find this inefficient for the project. What I would like to do is to increment the number of pulses through coding. This is my idea:
I will use 2 variables: one to record the knob position on the rotary encoder and another one to count the number of complete rotation. The problem is that I don't know how to get feedback from the previous state of the knob as if the position is now 1 and the previous position was 15, the program will know to increment the number of complete rotations by 1 and vice-versa.
The code is the following:
Code:
#include<htc.h>
#define _XTAL_FREQ 20000000
#define TMR2PRESCALE 4
long freq;
int PWM_Max_Duty()
return(_XTAL_FREQ/(freq*TMR2PRESCALE);
PWM1_Init(long fre)
PR2 = (_XTAL_FREQ/(fre*4*TMR2PRESCALE)) - 1;
freq = fre;
PWM2_Init(long fre)
freq = fre;
PWM1_Duty(unsigned int duty)
if(duty<=16)
duty = ((float)duty/16*6)*PWM_Max_Duty(); //this is divided by 16*6 as I want to have a max of 6 complete rotations and 16 pulses per rotation
CCP1X = duty & 2;
CCP1Y = duty & 1;
CCPR1L = duty>>2;
PWM2_Duty(unsigned int duty)
if(duty<=16)
CCP2X = duty & 2;
CCP2Y = duty & 1;
CCPR2L = duty>>2;
PWM1_Start()
CCP1M3 = 1;
CCP1M2 = 1;
#if TMR2PRESCALAR == 1
T2CKPS0 = 0;
T2CKPS1 = 0;
#elif TMR2PRESCALAR == 4
T2CKPS0 = 1;
T2CKPS1 = 0;
#elif TMR2PRESCALAR == 16
T2CKPS0 = 1;
T2CKPS1 = 1;
#endif
TMR2ON = 1;
TRISC2 = 0;
PWM1_Stop()
CCP1M3 = 0;
CCP1M2 = 0;
PWM2_Start()
CCP2M3 = 1;
CCP2M2 = 1;
#if TMR2PRESCALE == 1
T2CKPS0 = 0;
T2CKPS1 = 0;
#elif TMR2PRESCALE == 4
T2CKPS0 = 1;
T2CKPS1 = 0;
#elif TMR2PRESCALE == 16
T2CKPS0 = 1;
T2CKPS1 = 1;
#endif
TMR2ON = 1;
TRISC1 = 0;
PWM2_Stop()
CCP2M3 = 0;
CCP2M2 = 0;
void main()
unsigned int bi, rot;
PWM1_Init(5000);
PWM2_Init(5000);
TRISD = 0xFF;
PWM1_Duty(0);
PWM2_Duty(0);
PWM1_Start();
PWM2_Start();
do
bi=2^3*RB3+2^2*RB2+2^1*RB1+RB0;
//this is where i lack the code ideea
PWM1_Duty(bi);
__delay_ms(20);
}while(1);
