How to prevent line voltage drop of Batteries
Discussion in 'General Electronics Chat' started by edliu, Feb 27, 2011.
  1. edliu
    Feb 22, 2011
    11
    I have a question. What can I do to be able to substain a nominal voltage of 48V input from a Lithium polymer batteries of 12 of them in series(12S). I believe that after a certain usage, the voltage will drop to below 48V. However, my equipment needs to be on constant 48V input.
    Please advise me on how I can achieve it.
    Thanks!!!
  2. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Use a buck boost converter.
  3. Kermit2
    Feb 5, 2010
    3,849
    965
  4. edliu
    Feb 22, 2011
    11
    How does this boost converter help? Please advise
  5. Ctenom
    Member
    Nov 1, 2010
    59
    Buck boost converters take a lower voltage and increase it. However i believe Kermits idea is a much better one. how much power are you expecting to draw? Have you got low voltage protection for your battery? I wouldn't take a lipo cell below 3.0-3.5v (40v in your configuration) after that it gets dangerous. Also make sure they are all brand new and of the same make and model purchased at the same time. Ideally i would have something monitoring EVERY cell. Four/five 12v lead acid batteries would be better if used with Kermits idea
  6. russ_hensel
    Jan 11, 2009
    820
    47
    A buck boost can both step down and up. As a switching converter it does not dissapate energy as heat ( compared to a linear regulator ). Thus you may not need as many cells and batteries stay useful even after the voltage sags below the required voltage.
