how to prevent 2 switch from turning on at the same time?
Discussion in 'Homework Help' started by KaiL, Oct 22, 2015.
  1. KaiL
    Aug 30, 2014
    61
    This is my current H bridge circuit implemented using BJT. How should I go about so that when 2 switch are turned on at the same time , it will not result in a short circuit.
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    Use a single-pole, double-throw switch.
  3. Dodgydave
    Jun 22, 2012
    5,142
    768
    Use a changeover switch, centre to positive, ends to transistors.
  4. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    You could also use a DPST or DPDT switch with centre off, this way you would have three positions/conditions.
    Max.
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    You need to read and understand this forum thread.
  6. GS3
    Sep 21, 2007
    408
    35
    In fact, you can just use the mechanical switch and dump the electronics.
  7. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    I assumed the wire junctions in the bottom right were some kind of inputs (PWM?).
    Max.
