How to power motherboard with power supply
Discussion in 'General Electronics Chat' started by dazzer7, May 8, 2016.
  1. dazzer7
    May 7, 2016
    5
    [​IMG] [​IMG] [​IMG]
    This is a motherboard of an N64 console on the top right of the second pic shows 6 solder blobs which are
    1 GRND [​IMG] Ground
    2 Vcc [​IMG] 3.3V 2.7A
    3 Vcc [​IMG] 3.3V 2.7A
    4 GRND [​IMG] Ground
    5 GRND [​IMG] Ground
    6 Vcc [​IMG] 12V 0,8A
    MALE pinout on power plug itself
    _____
    |123|
    |456|
    1,4,5 = -
    6 = 12V DC 0.8A
    2,3 = 3.3V DC 2.7A
    FEMALE pinout on console
    _____
    |123|
    |456|
    1,2 = 3.3V DC 2.7 A
    3,5,6 = -
    4 = 12V DC 0.8A
    also the 3,3 V pins are interconnected, as are the three negatives,
    Does anyone know how I can hook up my adjustable power supply straight to this board to power this.
  2. ScottWang
    Aug 23, 2012
    4,925
    777
    Is this the motherboard of game made by Nintendo Japan?
    What is your adjustable power supply? (V/I)
  3. shteii01
    Feb 19, 2010
    3,500
    511
    Like Scott elucidated, it depends on the power supply. If you have dual power supply, you can set one to 3.3VDC, but you need it to supply 2.7+2.7=5.4A, then run two wires from V+, one for first 3.3VDC, one for second 3.3VDC, run one wire from V- to the ground on the connector. Then set the second of the dual power supply to 12VDC and 0.8A, V+ to the 12VDC on the connector, V- to ground on the connector.
    If you have tripple power supply, set each for individual voltage and current.
    ScottWang likes this.
  4. paulktreg
    Distinguished Member
    Jun 2, 2008
    622
    124
    If you don't have a dual power supply then you could use a PC ATX power supply, both voltages are available.
