from a LNB data sheet i got the phase noise of the LO as below:
-65 dBc/Hz @1 kHz
-90 dBc/Hz @10 kHz
-110 dBc/Hz @100 kHz
as these values are relative to the LO power, How can i get the actual values and can plot the phase noise. I don't find any info related to the LO power. Can some one help with link or any info regarding the typical values of LO power so that i can calculate the actual phase noise and plot it.
thanks in advance
Reza
-65 dBc/Hz @1 kHz
-90 dBc/Hz @10 kHz
thanks in advance
Reza
