How to plot a text data column from an excel file in MATLAB?
Discussion in 'Programmer's Corner' started by SarahQ, Dec 6, 2013.
  1. SarahQ
    Dec 6, 2013
    Hello, I have imported in Matlab an excel file that contains two columns, one with numeric values, and the other one with text values. The first 5 rows can be seen below:
    ABF-E 0.34
    HJK-D -0.54
    GHKL-I 1.34
    FPLO-5 2.3
    KKJLL-T 0.98
    I need to plot the numeric column on the Y axis and the text column on the X axis. I can easily work with the numeric column using xlsread and plot, but I can not manage plotting the text column. How could I do it?.
    I have written the following code, but I don't know what to do for the x Axis:
    filename = 'MyData.xlsx';
    Sheet = 2
    xlRange = 'B1:B60';
    Yaxis = xlsread (filename,Sheet,xlRange);
    Xaxis = ????????;
    plot(Xaxis,Yaxis)
    I would be very grateful if somebody could help me.
  2. MrChips
    Oct 2, 2009
    12,635
    3,454
    Get the data into a cell array
    and then use
    set(gca,'XTickLabel',cellarray)
    SarahQ likes this.
