How to orientate these Potentiometers?
Discussion in 'The Projects Forum' started by JDR04, Aug 5, 2011.
  1. JDR04
    Thread Starter Active Member
    May 5, 2011
    339
    Can anybody please tell me how to connect the pots in the following schematics?
    I'm assuming the centre/common pin of the pot is connected to pin 7 in the first schematic?
    I'm going to have a go at building a thermostat for my biltong box.
    Again I'm assuming that the centre/common pin of the pot is also connected to one of its "other" pins in the second schematic?
    I know assuming in electronics can be costly so any information from this forum will be appreciated. Many thanks JDR04 :confused:
  2. PeeSeeBee
    Member
    Jun 17, 2011
    43
    7
    The pot in the first diagram is also connected the same way as the ones in the second diagram. As well as the wiper (centre connection), one end of the pot also connects to pin 7. They are all wired as variable resistors (rather than potentiometers).
    So, yes, you are correct. The centre connection (wiper) also connects to one side of the pot.
  3. debjit625
    Apr 17, 2010
    790
    186
    Yes you are right in both the case.
    Yes,but thats how we all learn sometimes....
    Good Luck
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You should really post the entire schematic.
    Sometimes, people draw schematics without thought as to what might happen if pot(s) wired as rheostats were set to their minimum values; a frequent result is smoke. :eek: Hopefully, your schematic does not have errors like that, but it would be best to let us have a look before you try wiring it up.
