How to only allow 3v - 6v in circuit
Discussion in 'General Electronics Chat' started by palerider2029, Mar 16, 2015.
  1. palerider2029
    Mar 16, 2015
    18
    I've been using fixed 3volt LDO regulators, but I want to be able to allow any voltage from 3v - 6v. Are there similar components that will allow this?
  2. blocco a spirale
    Jun 18, 2008
    1,456
    369
    You need to provide more information...
  3. palerider2029
    Mar 16, 2015
    18
    I've got multiple battery configurations: 3v to 7.4v
    I want to run an LED light between 3v - 6v depending on the output of the batteries not less not more.
    If 3v output is 3v (1 x cr123)
    If 3.7v output is 3.7v (1x 18650)
    If 6v output is 6v (2 x cr123)
    If 7.4 volt output is 6v. (2 x 18650)
    Best if the component allows >500ma of current.
    I've been limiting the voltage to 3v using this component, but this does not allow the LED to perform at the brighter 6v settings when I install the other battery configurations.
    http://www.digikey.com/product-detail/en/MCP1702T-3002E/CB/MCP1702T-3002E/CBCT-ND/1979827
  4. blocco a spirale
    Jun 18, 2008
    1,456
    369
    Do you have specs for the LED? Sounds like you need a constant-current source.
  5. palerider2029
    Mar 16, 2015
    18
    The LED's already have drivers.
    One is 3v - 9v
    The other is 6v only
    Thank you for trying to help me. I really appreciate it.
  6. blocco a spirale
    Jun 18, 2008
    1,456
    369
  7. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,836
    1,308
    Well... If, as you say, the devices operate properly at 6v, your course would seem obvious? Am I missing something? :confused:
    Regards
    HP
  8. palerider2029
    Mar 16, 2015
    18
    I was hoping for a simple surface mount component, some type of IC. I'm not very familiar with what is out there.
  9. palerider2029
    Mar 16, 2015
    18
    Since I use 3v batteries I really need to limit the output to 6v, but still allow the 3v bulb to function normally if the input is only 3v.
    If I used a 6v regulator would it still function at 3v?
  10. Hypatia's Protege
    Mar 1, 2015
    2,836
    1,308
    It would not reliably pass the 3v 'through' if that's what you mean -- I strongly recommend you take the former poster's advice (Re: the linked devices) :)
    Best regards
    HP
  11. Hypatia's Protege
    Mar 1, 2015
    2,836
    1,308
    A diode "OR" arrangement may be useful -- though you'd need to select diodes exhibiting a low forward (bias) 'drop'...
    Really though, no need to be 'afraid' of the boost converters - they're 'self documenting' as it were :D
    Best regards
    HP
  12. Alec_t
    Sep 17, 2013
    5,956
    1,132
    Here's how you could do it :-
    Tempco is ~ -7mV per degree C.
  13. palerider2029
    Mar 16, 2015
    18
    Thank you for taking the time to show me this.
  14. Dodgydave
    Jun 22, 2012
    5,136
    767
    use a J113 fet in constant current mode,
    uses just 2 components one transistor and one resistor .
  15. palerider2029
    Mar 16, 2015
    18
    Would you mind being a little more specific?
    I like that the J113 comes in an sot-23 package.
  16. Dodgydave
    Jun 22, 2012
    5,136
    767
  17. palerider2029
    Mar 16, 2015
    18
  18. palerider2029
    Mar 16, 2015
    18
    In simplest terms I basically need gate that will allow any voltage through up to 6v, and then switch off if higher voltages are present.
  19. Dodgydave
    Jun 22, 2012
    5,136
    767
    If you want to shut off above a certain voltage you need a Comparator circuit, not a constant current,
    the constant current keeps the same level irispective of the voltage variation.
    What are you trying to make?
  20. palerider2029
    Mar 16, 2015
    18
    It is a head mounted flashlight system. It can use 6v surefire incandescent or LED lamps, or 3-9v Solarforce lamps with a variety of battery types.
    I'm trying to regulate the voltage to protect the surefire lamp from 7.4v battery configurations while still allowing the solarforce lamp to run at 3v if the user decides to use that style of lamp.
